Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Rear Axle Bump Stops
  #54 (permalink)
Old 11-07-2012, 09:27 AM
I wouldn't mind running the numbers on the coils for you if you have the actual rear weight of your car. Just need to know the weight for the rear, distance from shock mount to shock mount at drive height, And whether the shocks are mounted straight up and down or at a certain angle.
