Rear axle code - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-27-2007, 09:19 PM
Rear axle code
I pick up an old differential and was told it was out of a 70 chevelle. I was unable to find out where it came from looking up the codes. The code on the axle tube is ACC 298 1, and the code on the bottom of the pumpkin is 1243774.
There are a couple of other numbers on differential housing K-12 and J 12 4, D-N. It measures 55 1/4". Looking to see if it will work in a 65 chevelle. Any idea what it would have come out of?
Old 02-11-2014, 01:53 PM
I have the same axle, any luck figuring out what its from? Mine is in a 68' Chevelle
Old 02-11-2014, 05:44 PM
big gear head's Avatar
High Performance Rear Ends
What is the total width (backing plate measurements are not accurate). What do the spring perches look like. What does the cover look like?
Old 08-07-2014, 01:28 PM
Sorry for the REALLY late reply:
Here are some pictures.
Old 08-07-2014, 01:31 PM
That is the 8.5 10 bolt. If it's the A body rear end then it's out of a '71 or '72 Cutlass or Skylark and will be 61 inches wide over all.
Old 08-07-2014, 01:53 PM
Silver Surfer's Avatar
More machine than man
Last journal entry: bwaahhaahahaaahhaa
ACC (4.10) non-locking
10-1/2" ring gear
13x2-1/2" brakes
8600 GVW
Chevrolet 2500 pickup 96-00
4x2
GMC 2500 pickup 96-00 4x2
Page 186 as indicated by my PDF viewer.
Page 188 if you look at the actual page numbers as displayed on the document.
Found here:
http://www.theimportkiller.com/Holla...ion_Manual.pdf
I also have another PDF I found at one point, but it is at home. When I get back I can cross check it to see if they agree.
Old 08-07-2014, 01:56 PM
You may also have luck digging in here as well...
http://www.whateveristrue.com/chevy/...nformation.pdf
Old 08-07-2014, 02:02 PM
That is definitely not the 10.5 rear end.
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Help Me Identify the Rear Axle in my project? Bud's 27 T Touring Suspension - Brakes - Steering 7 05-29-2006 10:01 AM
Ladder Bar Rear Axle Centering gilesletheren Suspension - Brakes - Steering 6 05-18-2004 11:05 AM
2000 Camaro Rear Axle Housing 4811 Transmission - Rearend 3 09-16-2002 11:18 AM
