-   -   Rear axle de-code (http://www.hotrodders.com/forum/rear-axle-de-code-229651.html)
34Pont5window 02-17-2013 05:53 AM
Rear axle de-code
I have a 79 10 bolt rear end with 2:29 gears. The code is 2AH-C1022. What make model is this from? I want to buy e-brake parts for the drums.
SSedan64 02-18-2013 12:52 PM
Coil spring or Leaf spring rear?
Casting # on center section may be more helpful.
79 Cutlass, 2AH code = 2.29 Open Diff, the C = Chevrolet, Buffalo.
Reference Manual: Chapter 3: Axles: Factory Useage
Reference Manual: Chapter 3: Axles: Factory Useage: 1979
