Rear axle de-code - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-17-2013, 05:53 AM
Rear axle de-code
I have a 79 10 bolt rear end with 2:29 gears. The code is 2AH-C1022. What make model is this from? I want to buy e-brake parts for the drums.
Old 02-18-2013, 12:52 PM
SSedan64's Avatar
Coil spring or Leaf spring rear?
Casting # on center section may be more helpful.
79 Cutlass, 2AH code = 2.29 Open Diff, the C = Chevrolet, Buffalo.
Reference Manual: Chapter 3: Axles: Factory Useage
Reference Manual: Chapter 3: Axles: Factory Useage: 1979
Rear axle code Bill65 Transmission - Rearend 7 08-07-2014 02:02 PM
Rear axle code bodriver953 Transmission - Rearend 1 11-02-2009 07:23 PM
Rear axle code bodriver953 Introduce Yourself 3 11-02-2009 03:45 PM
10 Bolt Rear End Axle Code TORI1 Transmission - Rearend 13 03-31-2006 07:17 AM
Rear End Axle Code for the Chevy S -10's Traps Restoration Transmission - Rearend 1 02-27-2005 10:05 PM
