rear axle endplay query - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-16-2006, 12:51 PM
Hi there
I've had some good advice from this forum in the past, here's hoping you can put me straight on this. I have 69 Le Mans that I'm building pro-touring style, part of which is a rear end disc brake upgrade to the 8.2 rear. I've got a rear disc set up from a 79 Caddy Seville for the conversion.
Now the question is this, the stock drum backplate was approx 0.100 inch thick, the rear disc caliper bracket which swaps in is 0.200 inch thick. Is this difference of 100 thou going to cause any problems (eg endplay) and if so how do I fix it?
Thanks for your help
Tom
Old 09-16-2006, 01:04 PM
It shouldn't change the endplay as this is determined at the other end of the axle by the C-clips and the center pin.
Old 09-16-2006, 01:23 PM
Thanks
Sorry, I should have been more specific, the rear end is an 8.2 BOP without C clips, does your reply still hold true?
Thanks
Tom
rear suspension/Welding on Rear Axle redsin Hotrodding Basics 4 05-30-2006 09:25 PM
Help Me Identify the Rear Axle in my project? Bud's 27 T Touring Suspension - Brakes - Steering 7 05-29-2006 11:01 AM
Ladder Bar Rear Axle Centering gilesletheren Suspension - Brakes - Steering 6 05-18-2004 12:05 PM
Jag Rear Axle -- almost completed! farna Transmission - Rearend 5 02-28-2003 08:55 AM
