Rear axle help - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-06-2012, 10:45 AM
frickenbored's Avatar
383!
Rear axle help
I'm just about to rebuild my 1999 gmc jimmy's (not a hot rod, I know ) rear axle but I'm having a hard time figuring out what axle it is. I could be a 7.5rg, 7.625rg, or a 8.5rg.
I'm pretty sure its a 7.625 but I wanna be sure before I order all my parts. GM says that the 7.625 axle has 28 spline axle shafts, my question is will the pinion gear also have 28 splines? I'll b easier counting those splines then pulling an axle shaft.
Some info:
1999 GMC Jimmy
4.3L/4l60e
4wd
sle
towing package.
Thanks for any help.
Old 02-06-2012, 10:57 AM
stich626's Avatar
gearheadslife
Last journal entry: The TwoTonShu #10
99 it be 7.625 or 8.5
pull the cover...
tow package, my bets on 8.5
http://coloradok5.com/axleguide.shtml
Old 02-06-2012, 12:09 PM
383!
you might be right, looking at that link my diff cover does not have a fill/drain plug. I guess the only way is going to be pulling an axle shaft, I was hoping to avoid that.
Old 02-06-2012, 12:22 PM
prostreet6t9's Avatar
Differential/Driveline
7.625 will have 27 splines on the pinion.
8.5 will have 30 splines on the pinion.
Old 02-06-2012, 12:29 PM
stich626's Avatar
gearheadslife
no g.m. cover has one(drain plug..) at least not the corp 10 bolt..
8.5" cover
http://image.sporttruck.com/f/985974...gm_10_bolt.jpg
this one the 8.5" cover is on the left.. the 7.5/7.625cover is on right
http://memimage.cardomain.net/member...2_111_full.jpg
hope that helps
Old 02-06-2012, 03:42 PM
383!
that is the exact information I was looking for. Thanks man
Old 02-06-2012, 03:48 PM
383!
8.5" cover
hope that helps
It looked like a drain plug on the 7.5rg cover:
Old 02-06-2012, 03:51 PM
stich626's Avatar
gearheadslife
the photos in that link are to show the cover shape, aftermarket covers sometimes have drain plugs.. that one, that high up. is a fill not a drain
Old 02-06-2012, 04:33 PM
383!
right...I ment fill
Old 02-06-2012, 05:31 PM
Your welcome
rear suspension/Welding on Rear Axle redsin Hotrodding Basics 4 05-30-2006 09:25 PM
rear axle murfeey General Rodding Tech 1 05-21-2005 11:56 PM
rear axle sbc350 Transmission - Rearend 4 03-31-2004 01:33 PM
Rear Axle Help!!! 39chevy Suspension - Brakes - Steering 2 11-09-2003 09:02 AM
Rear End - 5 bolt axle shafts into 6 bolt rear axle??? Blue Chevy Transmission - Rearend 0 06-07-2002 06:23 PM
