rear axle hop - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-13-2007, 11:10 AM
rear axle hop
I have a 57 transtar pickup it has the original suspension with all new bushings and shocks it has 3 inch lowering blocks on the rear axle. The problem when Im driving it shakes bad at 45 mph any other speed its fine.I dont have the rear bed of the truck on yet so I can look right at the axle hopping around. Any help folks thanks BBB.
Old 11-13-2007, 02:34 PM
transtar
Bob,
Is that a Transtar as in Studebaker?
Seems like a good starting point would be to measure pinion angle and transmission output shaft angle.
Those centerlines should be parallel within a degree or two.
NR-Paul
Help Me Identify the Rear Axle in my project? Bud's 27 T Touring Suspension - Brakes - Steering 7 05-29-2006 10:01 AM
Ladder Bar Rear Axle Centering gilesletheren Suspension - Brakes - Steering 6 05-18-2004 11:05 AM
Jag Rear Axle -- almost completed! farna Transmission - Rearend 5 02-28-2003 07:55 AM
2000 Camaro Rear Axle Housing 4811 Transmission - Rearend 3 09-16-2002 11:18 AM
