Rear Axle ID Help - which car used a 12-Bolt posi w/ trailing arms (PIC) - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 08-16-2005, 09:16 AM
djjc76's Avatar
Ok, here are some images I took...
Could it be from a '72 Chevelle? Did the car use trailing arms?
  #17 (permalink)
Old 08-16-2005, 10:49 AM
djjc76's Avatar
whoops
oh geez....it's a 10-bolt!
  #18 (permalink)
Old 08-17-2005, 12:08 AM
Well it's definitely an 8.5" unit. The "15 41" is the tooth count on the gears (2.73 ratio), and the "72 12" is the manufacture date (Dec. '72) of the ring gear. I don't know what year they started using the S-shaped posi preload springs, but my '72 Nova unit has 4 coil springs, so I'd assume it's a '73-77.
  #19 (permalink)
Old 08-17-2005, 05:56 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
Originally Posted by djjc76
gear ratio is 2.73 (41 teeth on ring gear and 15 teeth on pinion). Both wheels turn together. There is a 15:41, 72, 8.75, etc stamped on the ring gear itself.
Assuming I use a 700R4, 350cui...would 2.73:1 be an ok choice to cruise on the highway? No burning rubber...
Everything you've posted show positively that it is a 1972 10-bolt axle.
I wouldn't recommend using the 2.73's behind a TH-700R4 unless you run some mighty small tires. This would be a great axle behind any transmission with a 1:1 high gear, the overdrive of .70 to 1 with 2.73's would give a final drive ratio of 1.91 to 1.
Going with 26 inch tires and an axle ratio of 3.73 and the TH-700R4 overdrive makes the final drive of my particular car 2.611 to 1
  #20 (permalink)
Old 08-17-2005, 06:08 PM
djjc76's Avatar
rear axle
yep, I am going with some small tires, 25.88" in outside diameter to be exact. I calculated somewhere online that with the current set-up, I can achieve 84 mph running 2100 rpm's...
Is there a difference between the '72 and '73 Chevelle rear ends?
  #21 (permalink)
Old 08-18-2005, 05:22 PM
That should be great for highway cruising. Assuming normal size tires it should turn about 3000rpm at 70 with a 1:1 final trans ratio. With the 700r overdrive it will be less.
  #22 (permalink)
Old 08-19-2005, 05:56 AM
12 bolt
You don't show the back plate, if it has a serpentine ridge pressed across it, it's Chev. No ridge, it's Olds, but A body for sure. Top arms are triangulated, Impala's had paralell upper arms and a panhard rod. F bodies were leaf sprung prior to 82. 2.73 posi 12 bolt probably means 71/2 bb Monte Carlo or Chevelle. And yes, too tall for a350/t700, how heavy, what size tyre?
  #23 (permalink)
Old 08-19-2005, 06:04 AM
10/12 bolt
Just saw the new photo's. 73/78 corporate a body. Not rare, was it cheap?
  #24 (permalink)
Old 08-19-2005, 09:32 AM
djjc76's Avatar
rear end
The rear axle was free. I cant complain about that! It's a 10-bolt, 2.73:1 gears, positraction. The ring gear was made in December of 1972 so it makes me believe this is a 1973 Chevelle or Monte Carlo? Here is the back plate:
New 12 bolt Rear/ questions. RObs71Nova Transmission - Rearend 1 12-27-2004 08:19 AM
What is This 12 Bolt Posi Out Of?? camaroman7d Transmission - Rearend 10 12-10-2004 05:57 PM
New 12 bolt rear? strikingthematch Transmission - Rearend 3 07-29-2004 12:41 AM
12 Bolt car and truck rear ends the same? zachscc Transmission - Rearend 2 01-18-2003 08:29 AM
12 bolt rear for a 1950 chevy truck solowookie Transmission - Rearend 3 11-17-2002 09:45 PM
