Rear axle removal GMC 1500 - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-19-2012, 08:52 PM
I am stuck on this .I need to replace axle seals on this truck going on old school to remove the axle and i am stump on this set up and removal of axle can any body help
Old 04-19-2012, 10:04 PM
Wiki Edits: 31
remove 4 bolts holding shocks on, u joint caps/straps and then the 8 u bolts. The U bolts should be replaced anyway. if there really stuck. just cut them.. You want to do this with the rear almost supported by stands and the truck pretty high up on a set of sturdy stands . a 2nd helper would be nice to pull the rear out from under it.
Old 04-20-2012, 10:36 AM
prostreet6t9's Avatar
Differential/Driveline
I think he just wants to remove the axle's... Not the whole housing.
Old 04-20-2012, 10:45 AM
Remove rear cover
Remove the 5/16 headed center pin bolt
push out center pin
slightly push axles in so c-clips can be removed
pull axle out
what is the stock rear axle ratio for a 1970 GMC pickup? rocken Transmission - Rearend 4 08-30-2010 05:45 PM
97 gmc 1500 97 GMC 1500 Internal transmission squeak Longbox262 Transmission - Rearend 5 06-25-2008 05:41 PM
1990 GMC 1500 rear end swap 90GMCVortec Transmission - Rearend 7 06-12-2008 11:23 PM
Lowering a 74 GMC 1500 TiMeWaRp Suspension - Brakes - Steering 11 01-15-2008 09:26 PM
'84 Gmc 1500 P/u restor84 Engine 0 05-25-2006 09:12 PM
