Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Rear Axle Replacement
Old 09-14-2002, 12:52 PM
woodz428's Avatar
woodz428 woodz428 is offline
Troll Hunter
Post
When the rearend is together, barring a tag number or such, lift both rear tires off the ground and rotate one , if the other one turns in the opposite direction it's not posi (make sure the tranny is in neutral), if it turns in the same direction it is.
