I'm thinking about changing the rear axle in an '82 chev. pick-up to a posi-trac. How can I identify a posi-trac and was there an '82 1/2 ton pick-up that came from the factory with a posi-trac?
When the rearend is together, barring a tag number or such, lift both rear tires off the ground and rotate one , if the other one turns in the opposite direction it's not posi (make sure the tranny is in neutral), if it turns in the same direction it is.
Do you know if GM installed posi-trac in '82 model pick-ups
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
