Rear axle spring on a "T" - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-15-2010, 09:46 PM
What kind of arch should be on a single rear axle spring?
Old 07-15-2010, 10:07 PM
BOBCRMAN@aol.com's Avatar
Enuff to clear the axle housing. Provide axle/ride movement. Provide proper ride height.. Describe which problem you are having.
Old 07-16-2010, 12:49 PM
Rear axle spring
On this T you only need one rear spring, it runs along the rear axle on the back side. It should be about 38" long x 1.75 wide with 8 leaf springs with the springs meeting in the middle, but I'm not sure what kind of arch it should have? I could guess and put a 9" rise on it but I have to order this spring and I'm trying to save some $$.
Old 07-16-2010, 04:52 PM
Typical "T" rear spring.. Try www.Speedwaymotors.com
Old 07-16-2010, 08:21 PM
Rear axle
Perfect...tahnk you very much
Relocating rear axle Augusto Transmission - Rearend 6 09-09-2009 09:11 PM
s10 coil spring rear fasttrain49 Suspension - Brakes - Steering 5 08-20-2009 07:51 PM
moving rear coil spring location to change rate cboy Suspension - Brakes - Steering 32 03-01-2007 12:31 PM
i got ford parts on my chevy rear axle roy383ci Hotrodders' Lounge 0 09-11-2005 04:31 PM
Rear Axle Leak Ford 9 inch zonk Transmission - Rearend 5 08-19-2005 07:30 PM
