rear axle true or not - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-31-2007, 12:00 PM
steve t's Avatar
ex biker, now hotrodder
will heating a rear axle to remove axle bearing wrap axle,on a 61 Chevy, i have a vibration in rear, jack car up right wheel has some run out or whobble
Old 03-31-2007, 02:13 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Shouldn't warp axle. That occurs when you unevenly heat the tube somewhere between the gear carrier and bearing flange. As long as your heat is concentrated in the bearing flange, no problem.
Old 03-31-2007, 03:15 PM
steve t's Avatar
heat was applied to axle and bearing out of housing to get bearing off of axle
Old 03-31-2007, 07:36 PM
Wiki Edits: 21
Shouldn't be a problem as long as you didn't heat the tube itself and cmncentrated the heat @ the bearing boss.
Help Me Identify the Rear Axle in my project? Bud's 27 T Touring Suspension - Brakes - Steering 7 05-29-2006 10:01 AM
Ladder Bar Rear Axle Centering gilesletheren Suspension - Brakes - Steering 6 05-18-2004 11:05 AM
Jag Rear Axle -- almost completed! farna Transmission - Rearend 5 02-28-2003 07:55 AM
2000 Camaro Rear Axle Housing 4811 Transmission - Rearend 3 09-16-2002 11:18 AM
