REAR AXLE WIDTHS - Hot Rod Forum : Hotrodders Bulletin Board
Closed Thread
Old 02-10-2003, 05:05 AM
Talking REAR AXLE WIDTHS
ANYONE KNOW OF A GOOD SITE THAT MIGHT SHOW REAR AXLE WIDTHS?I NEED ONE AT LEAST 60 " FLANGE TO FLANGE.
Quick reply to this message
Old 02-10-2003, 07:18 AM
zonk's Avatar
Home Built Rods No Rules
Last journal entry: Home Made Sheetmetal bender plans
Post
go to articles put in rear end widths then search should help
Old 02-10-2003, 08:13 AM
Jon's Avatar
Jon Jon is offline
Hotrodders.com Administrator
Wiki Edits: 7314
Post
You might also want to have a look at the <a href="http://hotrodders.com/kb/transmission-rearend/data.html" target="_blank">Transmission-Rearend:Technical Data section of the Hotrodders Knowledge Base</a>. The fifth resource on that page, entitled "Chart of Basic Rearend Measurements and Suspension Widths", may be exactly what you're looking for.
Old 02-10-2003, 10:11 AM
Talking
THANKS, JUST WHAT I NEEDED.
Old 12-17-2005, 10:44 AM
Try mid 70's early 80's GM mid-size cars
I don't know of a site but I can tell you from my experiences that I found a 60" wide axle in a '74 (?) Olds Omega (?) and that the axle width in a Pontiac Firebird (70's-80's) is approximately 62". I found this out by going to the salvage yard and measuring. I wanted the Firebird RE because it had disk brakes but it was too wide. The Olds had a 10-bolt posi and it worked fine.
Old 12-17-2005, 07:05 PM
48ChryslerRodder's Avatar
Stuck in the past.
Here is a site I found with some sizes listed, hope it helps.
http://www.carnut.com/specs/rear.html
Old 12-17-2005, 08:30 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Please pay attention to the dates of the threads..... this question was answered near 3 years ago.
Closed Thread
