rear bearing removal - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-30-2007, 07:10 PM
I have an 8.8 Ford rear end that needs the outer housing bearings replaced.... I can't get the old bearings out. Any old tricks to remove them short of buying an $80.00 slide hammer bearing remover?
Old 10-30-2007, 07:13 PM
bearing removal
I have a Ford 8.8 rearend that needs the outer axle housing bearings removed. Any suggestions... old tricks...? Any thing short of buying an $80.00 sliding bearing remover that I would use once every 30 years.
Thanks
Old 10-30-2007, 07:21 PM
sorry for the double post
Old 10-30-2007, 07:22 PM
sorry for the double post i guess I'm frazzled
Old 10-30-2007, 07:54 PM
Vortech 4.3's Avatar
jack of all trades
just an idea, never tried it = put the tire/wheel on it. then hit the tire with a large hammer. i have a slid hammer.
Old 10-30-2007, 08:26 PM
justold's Avatar
I have a drift pin that was made from an old 3/8 drive extention that would fit through one of the axel retaining bolt holes and I would hit it with a 3 lb or larger hammer , this wouldwork for all but the toughest ones . When that didn't work I would rent a puller . But on the other hand Advance Auto and many of the others will lend you the tools if you buy their parts .
just another thougt use a peace heavy about 6 ft fasten it to the axel on one stud slide a tire iron through a link on the other end and whip the chain
Old 11-04-2007, 11:09 PM
I used a $20 slide-hammer puller, but that barely got mine out. I had to tap one of them inwards slightly before it would move outward. Dang near wore me out. Might try the $40 one next time. Auto Zone will let you use theirs if you let them hold a cash deposit while you have it.
Somebody told me he used a long steel rod that would barely fit through the diff splines and punched them out from the other side of the housing. Sounds like a good story, but I never tried it.
Old 11-05-2007, 07:23 AM
"Somebody told me he used a long steel rod that would barely fit through the diff splines and punched them out from the other side of the housing. Sounds like a good story, but I never tried it."
Actually, I did just that, except I used a long peice of 1/2" Re-bar. Long enough to reach the back side of an axle bearing and still stick out the other end where I could hit it.
JA
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Problem setting up guts of ten bolt rwruther Transmission - Rearend 18 08-30-2007 10:07 PM
Bearing question for 10bolt rear killerformula Transmission - Rearend 9 05-25-2005 01:44 PM
57 chevy rear disc romine Suspension - Brakes - Steering 2 11-06-2004 05:43 AM
rear axle bearing 1badcamero Transmission - Rearend 7 12-10-2002 06:12 PM
