Is this rear bent? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-08-2007, 01:45 PM
1948 thames's Avatar
Is this rear bent?
I think my housing is bent. My tire is worn bald on the outer edge and the seal is leaking. I would like to get this fixed. Will it be hard to find a shop that can do this or should I just but another one?
Thanks.http://img.photobucket.com/albums/v4.../thames002.jpg
Old 04-08-2007, 01:50 PM
poncho62's Avatar
Wiki Edits: 5
Possibly, ...or, the rear end could be mounted crooked....ie: right side too far forward. How is the other tire?
The seal leaking means the bearing is probably toast.
Old 04-08-2007, 03:21 PM
Thanks for the info. The other side was wearing better, but it is wearing a little more on the inside. Not nearly as bad. I never thought about checking front to rear. Maybe I should mount it back onto the frame and measure and go from there. I don't have any way to tell if it's bent ( no fixture to check) other then finding a shop to ck it unless there is a way to do it with something that I don't need cut on a lathe.
Old 04-08-2007, 03:37 PM
dawg's Avatar
NAVY VETERAN
rear not bent but crooked in the car im betting
Old 04-08-2007, 03:52 PM
powerrodsmike's Avatar
Wiki Edits: 161
Usually if the rear is straight and mounted in the frame crooked the car will go down the road a little sideways.
I'm betting the housing is bent.
Take the wheel off, clamp a straightedge to the hubs on each side and measure for parallelism. Check the hub for straightness first, otherwise your measurements will be influenced by the crooked hub.
A good rear end shop can probably straighten that rear end out.
Another way to tell is to rotate the rear axle housing around . watch the tires, if the tops of the tires move in and out the rear is bent.
Or you can take the car with the rear end mounted to a alignment shop with a 4 wheel alignment machine, they can check it easily.
Later, mikey
BE different....ACT normal.
Old 04-08-2007, 06:02 PM
WDCreech's Avatar
Grumpy Old Goat Herder
If it's bent, which I think it is, the right side tube is bent forward from hard launches. I have a narrowed Ford 9" (without a back brace) that did the same thing. Do yourself a favor. Have it back braced when you have it straightened.
Bill
8.8 Ford rear end in my 79 G body Malibu 79 Malibu327 Transmission - Rearend 4 05-20-2007 03:26 PM
Hoods not shuting all the way 74_Chevrolet Body - Exterior 5 09-01-2005 08:10 PM
Rear End ID Riverman Transmission - Rearend 1 08-01-2005 08:21 AM
63 biscayne rear differential problems biscuit63 Transmission - Rearend 8 07-29-2005 05:37 PM
8.8 - Bent Housing or Bent Axle? 96cobra Transmission - Rearend 3 12-16-2002 06:30 PM
