It sounds like a frozen caliper. The cheapest way out is an exchange caliper as yours has a ratcheting piston design for the parking brake and requires special service tools to overhaul.
Some of the newer vehicle you have to turn it as you push it in with a c-clamp.
I dont know if this could be the problem,but i had one a while back on my camaro that locked up and would not release and i thought it was the caliper but insted it was the hose went bad, broke down inside and would let the fluid in but not let it out to releive the preasure on the caliper, replaced the hose and all was fine again.
Just crack the bleeder valve and see if the piston releases. |
| Need 1990 Bronco II Rear Brake Help | LarryA | Suspension - Brakes - Steering | 0 | 04-02-2007 08:38 PM |
| My 9inch rear end disc brake setup. | 1937FordCoupe | Suspension - Brakes - Steering | 0 | 01-15-2007 06:01 PM |
| Rear Disc Brake Pad Replacement | ccarccrazy | Suspension - Brakes - Steering | 3 | 01-13-2007 07:59 PM |
| Rear Disc Brake Conversion for '73 Impala | hduff | Suspension - Brakes - Steering | 11 | 10-22-2004 03:34 PM |
| 84 camaro rear brake conversion | Chevelle71 | Suspension - Brakes - Steering | 1 | 02-19-2004 04:06 AM |
