Rear brake light/turn signal problem new wiring.
I am trying to wire a hotrod, I have all the forward lights & markers working, turn, parking, etc. having trouble with the rear light circuit. Got parking lights, turn signals left & right, got brake lights, but when I actuate the brake light switch the turn signals stop flashing.
any ideas? What can I do to fix this? Thanks Bobwire |
Blue
This Will Work If You Have A Gm Column.from The Column Harness Splicea 16gauge Wire To Thewhite Wire,run This To A Terminal On Brake Lite Switch. From Other Terminal On Brake Lite Switch,run A Wire (to Recieve Power)to Hazard Flasher.from Other Term.on Haz Flasher Run Awire Up To Brown Wire On Column Harness. From Fuse Box Run A Wire (14ga)to Haz .flasher And Connect It To The Wire Going To Brake Lite Switch.(this Wire Powers Both Brake Lite Switch And Haz Flasher).from Another Fuse Run A 14 Ga Wire To Turn Signal Flasher.other Side Of Turn Signal Flasher Needs Wire To Purple Wire On Column Harness. Column Harness ---n Goes To Riteturn Stop Lite...m Tolft Turn Stop J To Rite Front H To Left Turn Front
check out this site. and download the schematic and troubleshoot .
http://www.oldengine.org/unfaq/signal.htm |
| this is a saver.... GM build codes | TooMany2count | General Rodding Tech | 24 | 11-23-2009 09:36 AM |
| Brake light problem | mightycarlo10 | Electrical | 6 | 12-18-2007 05:43 PM |
| wiring diagram for brake light/indicator? | pcoghlan | Electrical | 2 | 06-06-2006 02:58 PM |
| Hotrodders Knowledge Cluster: Disc Brake Conversions | Jon | Suspension - Brakes - Steering | 0 | 08-29-2003 03:34 PM |
| turn signal and brake light problem | PrimeMover | Electrical | 5 | 05-27-2003 06:26 PM |
