rear brake line? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-27-2006, 05:21 PM
tombo615's Avatar
rear brake line?
hey guys, i have a 1969 cutlass with a 12 bolt chevy rear out of a chevelle in it. i just started to do the rear brake lines and discovered that theres no provision for a bolt hole on my rear differential? does anybody out there make a special bracket that mounts the rear brake line to the differential? i could have sworn that on my old 10 bolt rear it had a provision for a bolt hole
any help would be much appreciated
Old 06-27-2006, 06:17 PM
rj57's Avatar
The '73 12 bolt posi I did own had a bracket for the brass T fitting attached to it.
This bracket had a hole in the other end that you placed one of the rear cover bolts through to hold the T fitting to the rear.
It shouldn't be too hard to find a T fitting like this at a swap meet, or even made a bracket to hod the T fitting in place?
Old 06-27-2006, 08:34 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
You can make a bracket out of a piece of small angle iron Or a small piece of flat metal bent into a "L" shape....drill a couple of holes..one for the T-Fitting and one to bolt to the rear end cover using one of your existing bolts.
Old 06-28-2006, 03:02 PM
tombo615's Avatar
damn really not in the mood to make the bracket
even though it will take 2 minutes
Old 07-02-2006, 07:24 PM
The Maintenance Geek
You could do what Ford of Europe did on the Capri,
run the hose to the rightside wheel cylinder, then
a hardline from the RR cylinder to the LR cylinder,
easy as hell to bleed...
Keith
Brake line components ? Old Reb Suspension - Brakes - Steering 2 06-29-2006 05:15 PM
How Does This Stuff Work? docvette Electrical 3 06-18-2006 03:00 AM
rear disk brake for newer model chevy truck woodmanscott@hotmail Introduce Yourself 1 12-21-2005 11:53 PM
Brake Line - 3 way fitting, one way only? BIGSKY Suspension - Brakes - Steering 2 11-17-2005 02:30 PM
