Rear brakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-26-2009, 03:18 PM
Mr.NutCase's Avatar
Rear brakes
1994 Olds Bravada 4.3L (vin W)
To bleed the rear drums, It has A.B.S on. No Scan tool/ Tech II need?
Are Raybestos brake wheel cylinders/hoses, a good brand?
What is the the torque spec for the u-bolts holding the rear diff?
I checked all autoparts, some carry cheap ones/not the right ones
A place that installs shock/struts/spring?
Old 11-17-2009, 04:26 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi Mr NutCase,
Raybestos are very good, they have been around forever
http://www.stengelbros.com/U-bolts.htm
The preferred method for bleeding ABS is with a vacuum bleeder,
also the bleeding order is from the master cylinder out then LF,RF,LR,RR
Good luck,
Rich
Old 11-17-2009, 05:55 PM
I have also successfully bled the brakes in ABS vehicles using only a vacuum bleeder tool.
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
1979 F250 Rear Brakes MrCoolDale Suspension - Brakes - Steering 1 07-14-2007 06:11 PM
Ford Explorer Rear Disc Brakes Lloyd Topping Jr Transmission - Rearend 4 11-10-2002 02:06 PM
rear drum brakes oldcarguy85 Suspension - Brakes - Steering 3 01-08-2002 09:41 PM
