Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - rear brakes locking up
Old 05-15-2010, 06:11 AM
tcoop tcoop is offline
Originally Posted by ken konoff
tcoop, I also have owned an 1984 C-10 for 22 years, have had the same problem when making a panic stop of usually right rear locking up. I have found after all these years what compounds the problem is if the brake drum lining is worn, or too thin the rear brakes lock up more often. Hope this might help another 84 C-10 owner. Ken
Did your truck have this problem the entire time you owned it, or did it start happening as the drums worn.
Actually, after you said that, I noticed that after I had the drums turned, it would do ok for awhile, but eventually they would start locking up again.
Did you eventually get your problem corrected?
Thanks,,,
