Rear brakes with no fluid - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 02-16-2011, 05:25 PM
Footstomper
Last journal entry: 40 ford/cadillac coupe
I called ECI today
I thought he might want to buy something to fix it. No, he did not. He said, When the pedal is stiff, it has a pre-load of fluid. I would drive around this morning first. I did it a again, when the fluid expand because the fluid gets hot. He told me to adjust the pedal, in my did not have a adjust, he says you need to give it a 1/2" or close, I had to pull the M/C to get to the shaft to cut the shaft, it was strange. I cut the shaft and I did not have any brakes to the floor. I changed the springs, that did not helped. So I just to put the tip of the shaft into the M/C. I have alot more pedal stopping half pedal. I tried the drive thinking it is going to get locking, I drived for about 20 minutes. It is fixed! It just need some place for the fluid.
Yea ha!
rear end disks brakes that bolt up in place of drum brakes that has a 383 465hp engin calon Introduce Yourself 2 01-23-2011 06:52 PM
No fluid through rear brakes 1972 Suspension - Brakes - Steering 3 05-02-2010 01:47 PM
12 bolt posi rear end fluid 1972bigblockchev Transmission - Rearend 3 06-19-2007 09:46 AM
Rear end fluid change stoney 81ta Transmission - Rearend 2 09-19-2006 09:25 AM
Never Changed Rear End Fluid Before 2506CYL Transmission - Rearend 3 02-22-2005 08:09 AM
