-   -   Rear Brakes are not working at all (http://www.hotrodders.com/forum/rear-brakes-not-working-all-218211.html)
lwin517 04-16-2012 06:44 PM
I am driving a 1956 Chevy PU, 75 Camaro front clip, 10 bolt posi rear from Nova. Disc front brakes, rear drum. Dual master cylinder with aftermarket vac booster. Front brakes work well, rears have little to no stopping power. I adjusted rear shoes and bled wheel cylinders, fluid comes out. Rear wheels will not even stop on jackstands. When I push the brake pedal the fluid comes out of the master cylinder ?? Possible bad MC or proportioning valve ? I'm at a loss at this point.
Thanks
poncho62 04-16-2012 06:50 PM
What are you using for a proportioning valve?
I have basically the same setup....I used the valve from the donor car that I got the clip from (76 Nova)....never had a problem with it
lwin517 04-16-2012 07:21 PM
I am using the after market brass one that goes on the side of the MC. It came with the MC , brake booster setup.
Cape Cod Bob 04-16-2012 08:26 PM
Are the rear cylinders old or been sitting awhile ? They may be stuck and need new ones :welcome:
lwin517 04-16-2012 08:49 PM
Wheel cylinders are only about a year and a half old. Guess I will have to have someone push the pedal gently while I watch the cylinder. Trying to figure why the fluid squirts out of the MC when the lid is off and pedal depressed ?
S10 Racer 04-17-2012 12:39 AM
Does it actually "squirt" out or just bubble up?
lwin517 04-17-2012 05:49 AM
It will actually squirt up if I push the pedal quickly.
S10 Racer 04-17-2012 02:46 PM
That is pretty normal. I think your wheel cylinders are probably stuck.
lwin517 04-17-2012 04:05 PM
Thanks, I will check this evening.
