Rear Brakes are not working at all - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-16-2012, 07:44 PM
I am driving a 1956 Chevy PU, 75 Camaro front clip, 10 bolt posi rear from Nova. Disc front brakes, rear drum. Dual master cylinder with aftermarket vac booster. Front brakes work well, rears have little to no stopping power. I adjusted rear shoes and bled wheel cylinders, fluid comes out. Rear wheels will not even stop on jackstands. When I push the brake pedal the fluid comes out of the master cylinder ?? Possible bad MC or proportioning valve ? I'm at a loss at this point.
Thanks
Old 04-16-2012, 07:50 PM
poncho62's Avatar
Wiki Edits: 5
What are you using for a proportioning valve?
I have basically the same setup....I used the valve from the donor car that I got the clip from (76 Nova)....never had a problem with it
Old 04-16-2012, 08:21 PM
I am using the after market brass one that goes on the side of the MC. It came with the MC , brake booster setup.
Old 04-16-2012, 09:26 PM
Cape Cod Bob's Avatar
Are the rear cylinders old or been sitting awhile ? They may be stuck and need new ones
Old 04-16-2012, 09:49 PM
Wheel cylinders are only about a year and a half old. Guess I will have to have someone push the pedal gently while I watch the cylinder. Trying to figure why the fluid squirts out of the MC when the lid is off and pedal depressed ?
Old 04-17-2012, 01:39 AM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
Does it actually "squirt" out or just bubble up?
Old 04-17-2012, 06:49 AM
It will actually squirt up if I push the pedal quickly.
Old 04-17-2012, 03:46 PM
S10 Racer's Avatar
That is pretty normal. I think your wheel cylinders are probably stuck.
Old 04-17-2012, 05:05 PM
Thanks, I will check this evening.
brakes going to floor but still working watchdude1 Suspension - Brakes - Steering 3 08-13-2009 09:31 AM
brakes arent working right 18camaro Suspension - Brakes - Steering 2 08-07-2009 03:07 PM
Drum brakes not working terminator0723 Suspension - Brakes - Steering 18 04-16-2009 08:50 PM
Please help young kid, who's still learning, to get his brakes working Warrant Suspension - Brakes - Steering 24 10-03-2006 12:06 PM
brakes just stopped working. yeeeeaaaaaaa! bullheimer Suspension - Brakes - Steering 9 06-15-2005 10:20 AM
