Rear Change on a Ford - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-23-2006, 08:37 PM
Hi Everyone, I'm needing some help on this project. I have a 54 Ford F-100 that has a chevy drive train in it. I want to take that rear out and put in a Ford 9 inch. The rear I want to put in is out of a 78 Lincoln Versailies with disc brakes. Will this unit fit right up to the truck??. It has the leaf springs on the bottom. Thanks to all!!! Don :
Old 10-23-2006, 09:05 PM
redlightning's Avatar
Don, Here is a good link with some info.
http://www.ford-trucks.com/article/i...ial_Swaps.html
I got a rear from a 66 in my 54.
Old 10-23-2006, 11:58 PM
Brian_B's Avatar
Lost in the 50s!
Last journal entry: time to start body work
Redlightening just posted the best article for the information you are looking for. I feel like I am following him around here.
My 56 still has the stock D44 rear axle (3.73). If it ever goes out, I have a early ford truck 9" (3.50) waiting to go in. They are the correct width too.
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
8.8 Ford rear end in my 79 G body Malibu 79 Malibu327 Transmission - Rearend 4 05-20-2007 02:26 PM
Explorer Disc Bbrakes on a 9" Ford Rear End Mustangsaly Suspension - Brakes - Steering 2 10-31-2005 04:18 PM
47 ford rear swap (parallel leaf springs) ONEGALONLY Suspension - Brakes - Steering 4 10-06-2005 07:06 AM
'39 Ford rear parallel leafs sandman351 Suspension - Brakes - Steering 2 05-13-2004 07:38 PM
