Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Rear Coil Over Shocks Questions - 48 Chevy
Old 11-27-2012, 11:34 AM
dsraven dsraven is offline
when i was figuring out what shocks to use on my truck I let the axle sit down against the frame, that is as low as it can ever go. then for the extended length i put the truck axle at droop 4" below the ride height, that is the total length of travel for my air bag. i did the measurements from the shock mounts at these heights and went from there. I was looking for shocks though, not coil overs. i went to the monroe site and found the specs chart. easy peezy.
