-   -   Rear Coil Over Shocks Questions - 48 Chevy (http://www.hotrodders.com/forum/rear-coil-over-shocks-questions-48-chevy-226573.html)
andrewakessler 11-27-2012 10:46 AM
I have just finished installing a triangulated four link onto my 48 Chevy pickup, and am now in the process of looking for rear coil over shocks. I used the following equation to determine a rough estimate of the shock sized I would need:
(shock travel) x 66% - distance between mounting points of shock at ride height = compression
and
(shock travel) x 33% + istance between mounting points of shock at ride height = rebound
At Summit Racing I found QA1 Pro Coil-Over Conversion Systems ALN2000K (QA1 Pro Coil-Over Conversion Systems ALN2000K - SummitRacing.com.)
Using my distance between mounting points of the shock at ride height (15 inches) and the travel distance of these shocks (5.125), I calculate my needs to be 16.69 rebound and 11.61 compression.
The shocks from Summit Racing are 16.250 rebound and 11.125 compression.
Have I done my calculations correct, and will these shocks work for my needs?
Thanks,
-A
dsraven 11-27-2012 11:34 AM
when i was figuring out what shocks to use on my truck I let the axle sit down against the frame, that is as low as it can ever go. then for the extended length i put the truck axle at droop 4" below the ride height, that is the total length of travel for my air bag. i did the measurements from the shock mounts at these heights and went from there. I was looking for shocks though, not coil overs. i went to the monroe site and found the specs chart. easy peezy.
BIGMIKE@RIDETECH 12-11-2012 07:25 AM
We always go for at least 5" of travel in the rear. With our current coil overs that puts you with a 14.5" to 15" drive height. Our 5"" stroke shock compresses to 11.23 extends to 16.43. If you need any help on spring rates let me know.
