Rear differential pinion shaft problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-06-2011, 10:35 PM
I have A 2000 Chevy Silverado with an eaton limited slip. I read the other post on problems with this diff. and I have got the other half of my locking bolt out. It looks like I may have wore a shoulder on the pinion shaft. I can get the shaft out about a 1/4in then nothing. If anyone has suggestions or advice that would be awesome. I am also looking into replacing the diff and am open to suggestions with this, I have looked at Detroit Locker's Truetrac and at an Auburn Gear limited slip.
Pinion shaft bearing? chevyrally68 Transmission - Rearend 4 11-29-2010 03:13 PM
Off-set Pinion Shaft dchatcher Transmission - Rearend 25 05-12-2009 07:39 PM
Removing seized pinion shaft 68NovaSS Transmission - Rearend 7 06-05-2007 12:38 AM
What if my Pinion is higher the my trans out put shaft? Quarter Flash Transmission - Rearend 2 09-11-2006 02:02 PM
63 biscayne rear differential problems biscuit63 Transmission - Rearend 8 07-29-2005 04:37 PM
