Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - rear disc brake conversion
Old 01-12-2009, 12:46 PM
streetrodderbn's Avatar
streetrodderbn streetrodderbn is offline
Certifiable Streetrodder
as long as the axles were re drilled safely with the correct bolt pattern you need, I'd just get another pair of drums and have them re drilled at a reputable machine shop, or even take your existing drums to a machine shop to see if they can be safely re drilled to properly fit the bolt circle. I have seen both rotors and drums plug welded and re drilled with no problems, it is the safety issue that warrants a certified welder or reputable machine shop for re drilling!!
