Hotrodders Bulletin Board > Tech Help> Suspension - Brakes - Steering
Register now (free) or login to remove ads
Thread Tools Search this Thread share on Facebook
  #1
Old 01-13-2007, 02:08 PM
ccarccrazy ccarccrazy is offline
Rear Disc Brake Pad Replacement
Hi,
I have an '01 Lincoln LS and I am about to change the rear disc brake pads. My question is, do I need to do anything with resetting the emergency brake? or will the piston callapse all the way like the fronts? I had an '84 Eldorado years ago that required resetting the emergency brake for the piston to collapse all the way.
Thanks, Gary
  #2
Old 01-13-2007, 02:52 PM
Bryan59EC's Avatar
Bryan59EC Bryan59EC is offline
Car? Truck? Who Cares
Last journal entry: First week of December
If it has a caliper similar to my 97 T-bird---
The piston itself screws back into the caliper bore.
Autozone sells a tool to do this----about 10.00
I just screwed the piston in just enough for the new pads to slip in.
No adjusting-----worked for me
Bryan
Old 01-13-2007, 08:45 PM
Thanks Bryan!
I am on my way to Autozone.
-Gary
Old 01-13-2007, 08:59 PM
xntrik's Avatar
xntrik xntrik is offline
Save a horse, Ride a Cowboy.
Use only Wagner Thermoquiet Brake Pads, turn the discs, or at least scuff consistently..... or you will probably be sorry.
After about 5000 miles you'll have lots of hard pedal and the sucker won't stop aggressively from 70 mph.
Been there, done that. Own 2 TownCars and a Mark 8.
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "Rear Disc Brake Pad Replacement"
ThreadThread StarterForumRepliesLast Post
drum to disc conversion kitsdmentedSuspension - Brakes - Steering406-06-2007 10:06 PM
Switching 71 Camaro 10 Bolt Rear End To Disc BrakesTORI1Suspension - Brakes - Steering104-13-2006 04:38 PM
swapping rear ends, brake question.....69elcaminossSuspension - Brakes - Steering203-30-2004 11:26 PM
Ford Ranger 8.8" Rear Disc Brakesnightrain_rodTransmission - Rearend106-23-2003 06:48 PM
Rear Disc brake conversion71CutSupremeSuspension - Brakes - Steering204-23-2003 12:49 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
