Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Rear Disc Brake Pad Replacement
Old 01-13-2007, 01:08 PM
ccarccrazy ccarccrazy is offline
I have an '01 Lincoln LS and I am about to change the rear disc brake pads. My question is, do I need to do anything with resetting the emergency brake? or will the piston callapse all the way like the fronts? I had an '84 Eldorado years ago that required resetting the emergency brake for the piston to collapse all the way.
Thanks, Gary
