rear disc brake ques. - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-17-2006, 06:00 PM
50 chevy p/u's Avatar
autoglass master tech
With the installation of eldorado rear calipers on my '50, I need a quick take up master cylinder. Does anyone know which gm cars used that type of m/c besides the caddy? Will a late model camaro or firebird m/c work?
Old 04-18-2006, 12:36 AM
Quick take up started getting phased in in 83.
Cars that I know have quick take up MC's
Latter B-bodies have 1-1/8"
F-bodies do too but the ports are on the passenger side to clear the strut mount.
Later G-bodies have them too but I don't remember the bore size.
S10's used a 15/16". Good one to use if you are worried about having too much peddle effort. Manual brake master has a smaller primary bore than the power master.
Good specs along with pictures can be found on www.napaonline.com
Old 04-19-2006, 10:38 AM
Thanks triaged
Old 04-19-2006, 12:12 PM
No problem
Ford Galaxie Disc Brake Conversion CrashFarmer2 Suspension - Brakes - Steering 5 04-10-2010 04:52 PM
Dent Repair Randy Ferguson Body - Exterior 25 11-26-2005 09:00 PM
57 chevy rear disc romine Suspension - Brakes - Steering 2 11-06-2004 05:43 AM
Wheel clunking and brake squeal skizot Suspension - Brakes - Steering 29 10-09-2004 06:17 AM
will these disc brake spindles fit my Torino? jchris64 Suspension - Brakes - Steering 2 09-07-2003 05:20 AM
