REAR DISC BRAKES - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-30-2002, 04:27 AM
BIGBLOCKSTANG's Avatar
New Member
Red face REAR DISC BRAKES
I HAVE INSTALLED REAR DISC BRAKES USING CAD 78 REAR DISCS AND I CANT SEEM TO GET A HARD PEDAL ANY HELP I HAVE PRESSURE BLEED THE SYSTEM SEVERAL TIMES AND WITH NO AVIAL THE ONLY TIME I HAVE A HARD PEDAL IS WHEN EMERGENCY BRAKE IS ON THE PEDAL IS HARD AS A ROCK. THANKS
[ October 30, 2002: Message edited by: BIGBLOCKSTANG ]</p>
Old 10-30-2002, 03:41 PM
Lightbulb
im installing rear disk brakes on my 70 nova and was told that i would experience the exact problems that you are experiencing if i did not get a master cylinder, proportioning valve and dual diaphram booster specific to cars with front and rear disk brakes. fortunatly i do not have to change mine out becuase im putting in front disc at the same time as the back and purchased the correct stuff. but check out mpbrakes.com for more info on the rear disk brake woooos.
Jeff
