Rear disc brakes leaking on my '66 Impala - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-17-2011, 01:26 PM
I transferred the rear disc brake setup from a 10 bolt to a 12 bolt rear end which I installed on my 66 Impala. Upon trying to bleed the brakes the fluid just gushed out where the brake line connects to the caliper.
I noticed that there are what appears to be brass or copper (or alloy) washers. I re-installed the same ones, one above and below the fitting that is connected to the caliper and tightened them down pretty snugly, but they still leak.
The hose itself is not leaking. Do the leaks occur because these washers need to be replaced (ie one use only)? Any other possible cause? See photos.
Thanks
Dave
Old 07-17-2011, 02:09 PM
poncho62's Avatar
Wiki Edits: 5
Get new brass washers
Old 07-17-2011, 02:49 PM
Pantaz's Avatar
They're called "crush washers" and they should be replaced every time.
They are available in copper or aluminum, but I think copper is recommended for brakes.
Old 07-17-2011, 04:31 PM
Thanks gents. Had a feeling that's what it was.
Old 07-17-2011, 04:40 PM
T-bucket23's Avatar
Wiki Edits: 26
I never change them. I always reuse the old ones. The replacement ones are usually of lower quality then the originals. make sure the washers and the surfaces are clean before assy and you wont have any leaks.
Chet
disc brakes on a 1966 impala chopperdave70 Suspension - Brakes - Steering 2 05-03-2008 09:53 AM
68 impala disc brakes Palerider Suspension - Brakes - Steering 3 11-03-2007 02:46 PM
Impala rear disc brakes rcc-impala Suspension - Brakes - Steering 1 11-26-2006 03:58 PM
61 Impala disc brakes DougMN Suspension - Brakes - Steering 3 03-29-2006 09:11 PM
Disc. brakes 63 impala s.s. Jack Griggs Suspension - Brakes - Steering 6 06-04-2002 07:05 AM
