Rear disc Cadillac calipers - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-07-2008, 06:08 PM
kleen56's Avatar
For a while I've been posting about my rear disc conversion on my 56 Ford F100. I was having problems with the rear disc working properly. I have the 85 Cadillac calipers with the builtin ebrake. Anyways, I finally got them working pretty decent. I had a 84 Monte Carlo MC mounted to a 8" power booster. Could not get the rear brakes to work no matter what I did. A few people in here suggested going with a 67-76 Corvette master cylinder which I did. I also replaced the line which had a hydraulic brake switch, which is worthless and put in a straight line of brake line. I had to bleed the rear caliper about 8 times before I got all the air out of the lines. I also set the proportioning valve to wide open on my Wilwood adjustable proportioning valve. With the Corvette MC, my rear brake are now stopping and actually stopping well without locking up the rear wheels. The Monte Carlo MC would barely stop the wheel and would allow you to turn the wheel by hand with the brake applied.
The Cadillac caliper are very difficult to work with and a pain to adjust. I guess there was a big difference with changing out the MC. I thought I'd let everyone know so when you attempt to do a project like this, maybe this info will help. I need to thank powerrodsmike for giving great advice and kinda helping me through this. 302 for letting me know that many hotrodders choose the Corvette MC for their disc conversions. And anyone else who gave me recommendations.
I was thinking about pulling the high 2.75 gears out since gas prices came down, but with the disc conversion, the entire brakes with brackets needs to be removed to pull the axles. Not sure if I want to mess with that since the brakes are functioning well.
Old 11-08-2008, 07:12 AM
454 Rattler's Avatar
NEVER SATISFIED !!
Thanks for the update. I wish more people would do a follow-up on their problems. It would help lots of people, I'm sure.
454 RATTLER
TIME 8:10 am
Temp 40*c
Gas $2.27/gallon
Old 11-08-2008, 10:24 AM
32v 32v is offline
i have found with the rear disc with built in emerg brake it has to be applied when parked to keep the pads close to calipher .when you apply the emerg.it takes the play out of the system its kind of a ratchet system.if you never use the e brake the rear brakes will go out of adjustment and not work very well .and when installing you must ratchet them manually so pads just rub the rotor
1971 Nova rear drum to disc conversion. 1971 Nova Suspension - Brakes - Steering 5 12-12-2006 03:07 PM
Switching 71 Camaro 10 Bolt Rear End To Disc Brakes TORI1 Suspension - Brakes - Steering 1 04-13-2006 03:38 PM
Ford C7AW E 9" Rebuild Help and Disc Brake Questions Mustangsaly Transmission - Rearend 12 11-06-2005 12:44 AM
Explorer Disc Bbrakes on a 9" Ford Rear End Mustangsaly Suspension - Brakes - Steering 2 10-31-2005 04:18 PM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 03:34 PM
