Rear disc stupidity - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-04-2009, 11:07 PM
kleen56's Avatar
Rear disc stupidity
I've had rear disc brakes for a while. I'm using the 85 Cadillac calipers which gives the luxury of having an ebrake. While on my way to a car show with my two boys, I notice my car was all of the sudden smoking heavily out the rear and the engine was sputtering and popping?. Figuring I had a blown something on the engine, I managed to drive it home. The harder I pushed the engine, the slower the truck would go. My boy said it smelled bad like someone was barbequeing. Checked the engine, everything was fine. Engine ran great at an idle. So, I figured I'd go back to the car show. It ran a little better but the smell was still really bad and the truck just wouldn't pull like it use to. Looked down and noticed that my emergency brake lever was still pulled up engaging the rear disc brakes. Released it and everything went well. The rims had some brake pad dust on them, and it appears there is no damage to the rotors, but haven't checked the brake pads. My friends tell me to just keep driving on them since they are fairly new, the brakes will be fine. Still has the smell of burnt pads though. Anyone else do this stupid stunt?
Old 04-06-2009, 05:41 PM
Not that I would admit to.
Trees
Old 04-06-2009, 06:22 PM
wildthing's Avatar
Last journal entry: running fine
i would at least check them. they maybe glazed from the heat and won't grab as well now.
Old 04-06-2009, 06:26 PM
kleen56's Avatar
I'm gonna pull the brakes in a few days. The rotors look OK, a little blue but no cracks. I'll sand the surface of the pads as well. The brakes have less than a 1000 miles on them, and I think that saved me. Won't do that anymore!
Old 04-06-2009, 06:31 PM
Cape Cod Bob's Avatar
Are you sure you won't do that any more ? I put a warning light on my SR to be sure. I had a swich on the gear shifter that I utilized and it will now be very difficult to make that mistake. Use to mhappen all the time before detroit came upm with the light idea.
Old 04-06-2009, 06:52 PM
kleen56's Avatar
Yea, the light is a great idea. I make it a point to look at the brake lever before I put the key in the ignition. The problem is, even with the ebrake engaged, the lever still looks like it could be released. I may opt for the light later on, in case stupidity kicks in again. Thanks for the advice.
Lincoln mark 4 disc brake rear whynot Suspension - Brakes - Steering 11 08-04-2010 05:16 PM
speedway rear disc dusterbd Suspension - Brakes - Steering 2 02-21-2009 07:10 PM
Switching 71 Camaro 10 Bolt Rear End To Disc Brakes TORI1 Suspension - Brakes - Steering 1 04-13-2006 03:38 PM
Dent Repair Randy Ferguson Body - Exterior 25 11-26-2005 09:00 PM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 03:34 PM
