Rear discs? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-21-2003, 08:36 PM
SS Monte's Avatar
Rear discs?
I am considering rear disc brakes for my 85 Monte SS. I like cheap and easy. What is the best route to go staying within those guidelines? Also plan to drag race the car with a 355, big cam, tunnel ram, th350. Any torque converter ideas? Thanks.
Old 10-22-2003, 10:01 AM
troy-curt's Avatar
Shop Owner And Troll Hunter
Find a mid 80s gm in the salvage yard with rear disc, they should bolt on. Trans am, camaro, etc. HTH
Troy
Old 10-22-2003, 10:29 AM
willys36@aol.com's Avatar
Wiki Edits: 21
Make your own. See my "Project of the Week" to see how I did it on my '36 Willys front end. Use front rotors (~$60 new at parts store or dirt cheap at the junk yard) and cluge together mounts for the calipers.
Old 10-22-2003, 09:55 PM
SS Monte's Avatar
Thanks for the info. , greatly appreciated
