rear drum brake problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-18-2005, 08:32 PM
New Member
Hello to all,
this doesn't pertain to the 58, but have a question about my 2002 toyota tundra. My rear brakes have been sticking and/or locking up at slow speeds. I pulled the rear drums off and have a mess of oil/grease all over the pads/rotors. I checked the master cylinder and it is full, so I'm assuming that it's from the rear end. I have never torn into this before, so I'm assuming that there is a seal of some type there. Any info on how to get to what I need to to fix this? Any info is greatly appreciated.
Old 09-19-2005, 07:07 AM
M&M CUSTOM's Avatar
Wiki Edits: 9
The best way to find out how to get in there and fix the problem yourself, would to find a Haynes or Chiltons repair manual, or spend the big money and go to the dealer for the factory service manuals.
The above mentioned will walk you through the process.
97 Ford f350 rear axle nut problems. Rubberman2003 Transmission - Rearend 5 03-21-2009 07:21 PM
Removing Rear Brake Drums Malibucdl Suspension - Brakes - Steering 11 05-08-2005 10:04 PM
swapping rear ends, brake question..... 69elcaminoss Suspension - Brakes - Steering 2 03-30-2004 10:26 PM
69 Camaro rear disk brake conversion? 69RatSS Suspension - Brakes - Steering 0 04-18-2003 10:17 AM
Rear end swap problems datsun dale Transmission - Rearend 1 12-17-2002 10:50 PM
