Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - rear drum brakes
Old 01-07-2002, 05:44 PM
liquid_larry liquid_larry is offline
I would check with your local parts stores like napa they would most likely have to order what you need but should be able to get parts for your car. Since I don't know what condition your brakes are in now or how long its been since the car has been drove it's a hard question to give a simple answer to. For your rear brakes get your drums turned,new hardware, springs and etc.,new brake shoes,and either rebuild or replace your wheel cylinders.While you have the drums off check for any grease leaking which would indicate bad axle grease seals, also look over your brake lines to be sure they are not rusted through. The safest way is to do everything now so you don't have prolems later.
