Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - rear drum brakes
Old 01-08-2002, 09:41 PM
poo poo is offline
these guys are right on point. Just keep in mind you should never scrimp on the braking system for any reason. NAPA is a great source for the parts. Also, if you are planning rear end swap and opting for disc setup keep in mind you'll need to plan for the appropriate dual master cylinder and an adjustable proportioning valve.Good luck partner.
