rear drum to disc conv. - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-17-2003, 01:46 PM
nd500's Avatar
New Member
Post rear drum to disc conv.
Anyone know a cheaper way to convert rear drum to disc brakes on a 1980 trans am. A machinest told me he could make brakets for me and get front calipers and rotors from a ford festiva. would this work? Any other ideas?
Old 05-17-2003, 04:39 PM
adtkart@aol.com
Post
I don't know anything about the Festiva front brakes, but you will need some kind of parking brakes. Don't think front calipers will be set-up for that. I personally would be more inclined to go with something that has larger brakes.
Old 05-19-2003, 04:14 PM
Mirror Image's Avatar
Post
You may wont to look in bone yards some of those cars came with 4 wheel disc brakes like the Nascar and turbo cars
Old 05-20-2003, 04:57 AM
farna's Avatar
Last wiki edit: AMC V-8s Last photo:
Wiki Edits: 14
Post
Some front drivers have park brakes on the front calipers. I know Subarus do. The Festiva front brakes should be adequate for rear brakes on a larger car. If you want a park brake you'll have to use a caliper that has 'em or go with a pinion shaft brake. I've seen a couple advertised, basically a manual caliper that clamps on a small rotor that bolts to the universal joint mounts on the pinion. With that you can use GM front calipers on the back. I think S-10 4x4 rotors come off the hubs like a drum, so they can be used. Speedway (www.speedwaymotors.com -- they have a cool catalog with lots of info as well as stuff!) sells a kit for $275 minus calipers. Brackets, rotors, all hardware. Put GM front calipers on and go. The machine shop might be your best cost alternative. Speedway has bolt on as well as weld on brackets, or you can order a piece at a time.
Old 06-18-2003, 05:46 PM
bullheimer's Avatar
NEVER use credit cards!
should know, but you know how that goes. since it's a 2nd gen you can try this other site www.nastyz28.com and see what they have over there since your car is essentially the same thing. happy hunting
Old 06-19-2003, 11:48 PM
Forkliftguy's Avatar
Crazy Canadian, woohooooo!
Try checking out a wrecked Pontiac Fiero, it has four wheel discs. The bonus is that the rear callipers have the park brake built in. GL
Old 06-19-2003, 11:59 PM
troy-curt's Avatar
Shop Owner And Troll Hunter
I used lincoln roters redrilled for chev axles with cady calapers
with emg. brakes
Troy;
Old 06-20-2003, 12:03 AM
troy-curt's Avatar
By the way didn`t some of the mid 80s trans ams and camaros have rear discs. You might try some of those.
Old 06-20-2003, 10:18 PM
84bird's Avatar
yeah, they do. mine atleast. look at the trans ams/irocs
