If everything looked good when you fixed the adjuster from being frozen up, Then re-adjust them again run them up till you feel some pretty good drag on both sides drive it a bit then check them again. If this is all you done was fix the adjuster and all was good with everything else shoes and things you probably need to go alittle tighter on your adjustment, You might want to re-check to make sure that no springs have came off after you fixed the adjuster. JMO. Cole
Those brakes are self adjusting. If they are loosening up, the adjusters are switched side for side.
My guess is that you put something back together wrong and the self adjusting arm is not keeping the adjustment from backing off.
I would pull the wheel that was frozen and make sure the adjuster is not able to just spin free. It worked for a long time, most likely the adjustment was off due to the frozen adjuster. You freed it and it is giving you issues. When you adjust the brakes be sure to lock them right up then back them off about 6-8 clicks.
Artificial Intelligence is no match for Natural Stupidity Chet |
| aligning hood | gto_ron | Body - Exterior | 8 | 03-25-2009 06:22 PM |
| Best ways to straighten a twisted repro door? | Ripped | Body - Exterior | 13 | 07-04-2005 07:29 AM |
| Chevy 1500 Rear Suspension Adjustment after lowering | jpd37 | Suspension - Brakes - Steering | 10 | 05-31-2005 05:36 AM |
| 57 chevy rear disc | romine | Suspension - Brakes - Steering | 2 | 11-06-2004 05:43 AM |
| body panel alignment | gmonkey | Body - Exterior | 5 | 09-01-2003 06:50 PM |
