rear end 1964 nova
having problem finding rear end for my nova need a posi. unit.
62-67 nova possi rear end
a rear end from a early ford bronco, i think it's called a B body will fit under a early nova with out having to shorten it. 52 1/8" backing plate to backing plate if I remember correctly. Cut the leaf spring mounts of a stock Nova rear and weld them to the Ford unit. You now have a 9"Ford under the Nova. I filled mine w/a Detroit locker center, a little harsh for the street but never a problem. I also installed a multi leaf spring and a sway bar. Be sure you weld those spring perches onto the ford housing correctly, the drive shaft needs to be in phase w/the transmission or the car may vibrate. I think it's 3 degrees above the center line and the trans is 3 below the center line. do some research on this.
| 66 nova rear end | robbysapien | Transmission - Rearend | 5 | 08-01-2007 07:48 PM |
| Nova Rear End - Wide Tires | Delirious2000 | Transmission - Rearend | 3 | 07-06-2006 02:48 PM |
| 77 Nova rear end compatibilty? | tms | Transmission - Rearend | 12 | 05-08-2006 05:13 PM |
| 64 nova rear end width | risaacp | Transmission - Rearend | 2 | 05-05-2004 12:03 PM |
| 70 nova rear end 355'swhat no.splines | oldnable | Transmission - Rearend | 5 | 07-18-2002 11:39 AM |
