Rear-end for 1974 J10 Truck Jeep - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Hotrodders' Lounge> Introduce Yourself
Old 12-13-2004, 09:06 AM
Hello everyone. I,m Jim or jp. I have a Jeep Truck 1974J10 AMC Need to find gears (ring&pinion-)have not figured Gear Ratio.Is there anything (besides counting Teeth. I also found numbers on the TransferCase in the front on the houseing. They are 5352094 46-13-3-54
Old 12-13-2004, 04:56 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Welcome to the board. The answer is in the code 46-13-3-54. IT says there are 46 teeth on the ring gear, 13 teeth on the pinion gear for a 3.54 ratio (46/13 = 3.5384615). That's perfect for a street strip car!!
This question should be posted in the Transmission rear end forum. This forum is for general introductions only and tech questions don't get very good coverage here.
Old 12-13-2004, 06:36 PM
Thanks
: Thanks. Appreciate the info.jp
