3.73 is a common gear ratio for the 4cyl. in any case 26 or 28 spline 7.5" depending on year. Possible somthing else got swapped in. If the pinion flange is flat and needs an adapter, it's a Ford explorer 8.8" and if the axle tubes are tapered then it is an 8.5" S10 rear
Ok, thanks! I guess I will see when I install the TH350 tomorrow. My last S10 had a 4cyl with the OD auto and a 3.73, so the V8 swap with the TH350 I would be around 3000 rpms @ 65mph, I can take a guess with this one. I could jack up the rear, spin the tire and see how many revolutions the shaft turns to 1 turn on the tire. I was trying to avoid taking the pumpkin cover off to see if its a LS or posi, but I might do it anyway, gives me an excuse to change the fluid!
| Welding a rear brace on a ford 9 inch rear end | makaveli200369 | Transmission - Rearend | 4 | 07-02-2009 10:19 AM |
| 70's 12 bolt rear to replace 80's 8.5 rear | MRGM | Transmission - Rearend | 4 | 02-07-2008 08:25 PM |
| 1/2 tonn burb rear and 1/2 tonna blazer rear.. u joint? | boneyard Buick | Transmission - Rearend | 1 | 10-08-2006 11:46 PM |
| Ford 9" rear end vs stock 89 chevy truck rear end | jimmy p | Transmission - Rearend | 2 | 12-07-2005 03:28 AM |
| 67ssdiagram showing how the rear sway bar and control arms connect to frame and rear | DeathByGreaser | Transmission - Rearend | 0 | 02-08-2003 08:10 PM |
