rear end - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-24-2011, 03:25 PM
Sigmaa BOX
rear end
I am getting my 350 motor converted to 383 stroker, do I have to switch out the rear gears?
Old 10-24-2011, 03:48 PM
Gears
It all depends on the weight of the car and what type of driving your going to do. Go like crazy light to light or cruise comfortably. 3.55 is a good all around gear. Oh yeah, it depends if you have an overdrive transmission or not.
Good luck
Old 10-24-2011, 03:51 PM
Sigmaa BOX
I will probably drive one day a week, it is 1987 Chevy caprice
Old 10-24-2011, 04:03 PM
A posi and 3.55 gears would make it a fine overall ride. What about the transmission?
Old 10-25-2011, 01:37 AM
American Muscle's Avatar
305 Turbo-Fire 240hp
what size tire also?
Welding a rear brace on a ford 9 inch rear end makaveli200369 Transmission - Rearend 4 07-02-2009 10:19 AM
70's 12 bolt rear to replace 80's 8.5 rear MRGM Transmission - Rearend 4 02-07-2008 08:25 PM
1/2 tonn burb rear and 1/2 tonna blazer rear.. u joint? boneyard Buick Transmission - Rearend 1 10-08-2006 11:46 PM
Ford 9" rear end vs stock 89 chevy truck rear end jimmy p Transmission - Rearend 2 12-07-2005 03:28 AM
67ssdiagram showing how the rear sway bar and control arms connect to frame and rear DeathByGreaser Transmission - Rearend 0 02-08-2003 08:10 PM
