Rear End for 37 chevy - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-12-2009, 12:31 PM
Can anyone tell me what the best late model rear end to put in a 37 chevy ?I would like to find one that would not be that hard to install.Are is there a way to leave the org. rear end in and change it to 5 lug.
Old 05-12-2009, 02:22 PM
302 Z28's Avatar
What are your plans for the 37 Chevy as far as engine? If your installing even a warm SBC the stock 37 rear will not take it, unless you never put your foot into it. If it were mine and I was installing a SBC I would go with a Ford 9". Ideally keeping it all Chevy would be great. Unfortunately a Chevy 12 bolt axle is very expensive. A 10 bolt Chevy axle would be easy to come by and is durable enough for a warm 350 SBC.
Vince
Old 03-03-2012, 11:30 AM
Best rearends to use are Ford 8" out of a 69 mustang, Plymouth Volare 1976, Chevy S-10 4x4 several years fit (2 wheel drive is too narrow), 67-69 Camaro and Firebird will work as well. Ford Explorer will work but it has an offset center.
Old 03-03-2012, 09:21 PM
327NUT's Avatar
Sodas...this thread is almost 3 yrs old....but has good info.
1941 Chevy transmission and rear end lubricant. CrashFarmer2 Transmission - Rearend 2 06-30-2008 06:17 AM
47 Chevy Coupe Rear End Change ? bluesman2333 Transmission - Rearend 12 06-24-2008 03:47 PM
pre-65 Chevy rear end info-- anyone knowledgeable? matt_ramsey Transmission - Rearend 6 03-29-2005 09:00 AM
Chevy rear end swap Truplayainfla Introduce Yourself 1 10-23-2004 11:07 PM
Rear end swap problems datsun dale Transmission - Rearend 1 12-17-2002 10:50 PM
