Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - rear end
Thread: rear end
Old 07-09-2002, 06:57 PM
Rex Tribble Rex Tribble is offline
Actually I believe that if you are ordering an axle housing they will want the flange to flange measurements. This is basicly the same as the back of the brake hub to brake hub measurements.
However the back spacing of the wheels you intend to use will require consideration when ordering the housing.
