We're winning the case!
Hotrodders Bulletin Board > Tech Help > Transmission - Rearend
  #1
Old 07-30-2005, 10:09 PM
DV8's Avatar
DV8 DV8 is offline
Sloe Lurner
Rear End for 54 chev??
I can get a rear end out of a 84 TransAm with Posi and Disk brakes. However it is not close by and is going to take alot of effort to get to. As in still buried under a car in somebodys barn. Does any body know if it will fit under my truck. I'm going to use a TCI 4 link rear end and panhard bar. I've run through most of the links and sizes and cant find one for this application. Thanks for any help!!!
MIke
Old 07-31-2005, 09:08 AM
Centerline's Avatar
Centerline Centerline is offline
HotRodsAndHemis.com
Centerline's barnstar
Wiki editor
Last wiki edit: Streetbeasts fraud controversy
Wiki Edits: 38
The 89 Trans Am had a 62" rear and the 84 is the same body style so the rear should be the same or nearly the same width. For your truck a 62" rear will work fine.
Old 08-01-2005, 03:31 PM
DV8's Avatar
DV8 DV8 is offline
Sloe Lurner
Thanks
Thanks Centerline thats ppretty much what I thought the 89 and 84 are both 3rd gen f-body cars. The owner does not know the condition of the limited slip are they hard to swap out??
MIke
Old 08-01-2005, 04:29 PM
Centerline's Avatar
HotRodsAndHemis.com
Wiki editor
Wiki Edits: 38
It actually depends on which housing it has. None are more difficult than the other but if it has the small housing you could be somewhat limited on gear selections. Mine came out of a 78 Firebird and had the small housing. The highest gear ratio I can fit in there is 3:08. It was pretty much a smog rear anyway and my truck is set up for highway cruising so it fit with the general scheme of things anyway.
I doubt the 84 will have the small housing but check just to make sure anyway. Good luck.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Rear End for 54 chev??"
this is a saver.... GM build codes TooMany2count General Rodding Tech 23 11-21-2008 07:27 PM
S-10/Camaro Rear End slaveforthewave Transmission - Rearend 7 02-20-2006 01:44 PM
Ford 9" rear end vs stock 89 chevy truck rear end jimmy p Transmission - Rearend 2 12-07-2005 03:28 AM
Dually rear end swap slomotion Transmission - Rearend 5 06-20-2004 09:50 PM
Ford 7.5" Rear End Traction-Loc Install nightrain_rod Transmission - Rearend 2 12-30-2003 06:38 PM
