Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - rear end
Thread: rear end
Old 04-08-2006, 02:53 PM
30desoto's Avatar
30desoto 30desoto is offline
Dodge ain't all bad
glen
Are you sure you have 307 gears, I have never seen a 4x4 with those gears or you would get better milage than you say most gears are closer to 390's on 4x4. Do you have a 350 in the truck what size carb, do you have headers, have you thought about putting in hubs it would help a bunch in milage to get it out of 4 wheel drive, what size and type of tires are they big lug or all weather, how does she run, does the carb need rebuildt, when did you change the oil last, how is the air filter, what type of air filter, when was the last tuneup on your rig, I know these are all small problem questions but each one can make a difference in your milage.
By the way welcome aboard
30dee
